Online: beaglebasher
Removing Tail Light
  • markmckenz
    markmckenz
    Is it possible to remove the rear tail light and use the rear indicators as brake lights and turn signals like the UK?
    Would this also be illegal here?
    Another ask is, where can you buy black bullt indicators and how do you change them out? My first Harley so still learning all the tips and tricks.
  • markmckenz
    markmckenz
    Fair call, I guess with them removing the tail light that would work.
    Would there be much wiring involved with fitting the 2013 signals in replacement of the 2012 separate tail light and signals?
  • markmckenz
    markmckenz
    Thanks!
    If anyone has done this before please feel free how to do it!!
  • Big Steve
    Big Steve
    I think this will do the job no?
    http://jokermachine.com/products/harley-davidson/turn-signals-marker-lights/badlands-led-intensifier-converter.html
  • Train
    Train
    The 2013 street bobs have break lights integrated into blinkers, so do some sportys. I think its legal
  • robots
    robots
    hi,
    you need to have an amber flashing indicator, not red I believe
    pretty sure hmmm2 on the money with the 48's having that particular set up, goto a dealer and just flick a 48's indicators on
    HD sell them
    thanks
    robots
  • BradndAlly
    BradndAlly
    Hi Guy's,
    Haven't been online for a while and just seen the link.
    I am in the progress of changing to the stop/turn/tail setup. I have used Dynamic clusters from customdynamics.com in the US. My biggest problem has been getting the holes in the guard cut out and a new piece welded in then getting it repainted (Sedona Orange $$$$)
    You wild also need a load stabilizer for them as well. Have them all installed. They fit straight in the old bullet indicators and have a plug which goes into the indicator bayonet fitting and then drill one hole through the reflector which doesn't get used anymore anyway for the two extra wires on them that you tap into the brake and tail light wires. Can't wait to get my guard back and ride it on the road. Will attach a photo when complete.
    GEN200-AR-1156-T $81.00(US) for pair of LED clusters
    GEN-HD-STABILIZER $64.96(US)
    Postage about $40.00(US) I bought other stuff as well
    Bradndally
  • BradndAlly
    BradndAlly
    Ta Bloody Da,        My finished run/stop/turn project. With a guard I ended up getting from the US.
    Yo can see the dynamic clusters thru the indicator lenses.............
  • Fe883
    Fe883
    Great looking bike BradndAlly.
    MarkMcKenz, My Sportster has LED rear Tail/Ind/Brake lights in one assembly. So it can be done, good luck.
  • BradndAlly
    BradndAlly
    Thanks Guys, just trying to be different....
  • robots
    robots
     Hi,
    i just about to put the dynamic clusters in like bradndAlly, got them the other week and have pulled apart turn signals just to check things out
    Plugged in to try out and they flash normal for a second or two then speed up so would say need the load sstabiliser
    thanks
    robots
