Online: Soapbox2627, beaglebasher, baccalaureateclasses, Hilly
Rotor stator removal
  • softy_84
    softy_84
     Hi, anybody got any tricks on removing harley rotor stator on an evo , have tried pulling it with strong wire , tried a steering wheel puller , tapped it a little. Anybody got a trick to get it off before I go buy the puller?
    it should come off with your steering wheel puller nip it up bit of tonshion then tap the end of your puller ,it shouldent be that tight anless the splines are floged,and  have welded together from moving , just dont tap to hard as you dont want brake the magnets on the rotor good luck
  • softy_84
    softy_84
    Thanks mate will have another stab at it
  • softy_84
    softy_84
    Thanks again mate , she only needed a little tap on the puller . Rotor was stuffed anyway tho. Cheers
