Online: Soapbox2627, Hilly
Rocker C Dyno by Ant at Maztech
  • RockerStu
    RockerStu
    Finally managed to coordinate a time for a tune with Ant at Maztech - results are below.
    The bike is a Rocker C with Bassani exhaust and stage 1.   Ant was "quite impressed" with the initial tune..it was putting out about 75hp to start with.  As you can see below, Ant has given it about another 20%.  It pulls and keeps pulling in high revs...rides like a new bike.
    Highly recommend Maztech.  Brilliant results.
    On another note, when I picked the bike up, the pipes were quite black from all the heat.  Ant recommended the following polish, which brought the pipes back to new without to much elbow grease - great product.
    after polishing
  • buznuts
    buznuts
    Thanks for the word
    Stuart,
    Knees in the breeze and enjoy your new ride, also glad you love the polish, you looked a little doubtful when I told you it should polish out :).
    Before anyone goes mad about the uneven graph, the only way I could tie his bike into the dyno was allowing the wheel to mrock up and down on the roller which tends to give a line like that as it plays havock with the load cell. Either way the number is not the issue it is the customer happpy with his bike. Just FYI!!
    Cheers- Ant
  • RockerStu
    RockerStu
    Ant,
    I was more than a little doubtful...but happy to be proven wrong - I didn't think there was a chance they would get back to normal !
  • pat
    pat
    How much do you charge?
    Thanks Pat
  • Sparra
    Sparra
    What type of tuner do you have and do they tune will all types???
  • RockerStu
    RockerStu
    Sparra - I have the Screamin Eagle tuner - I believe that they can work with lots of different tuners, but have no idea which ones - best you call Ant at Maztech with your questions.
