A quick guide to model, lean angle and ground clearance.
    **## Updated with bike weight and new Breakout model.**
    G"day forumites, Here is a quick guide I made up for the various model codes, ground clearance height, and left and right lean angles for 2012 and 2013 standard unmodified bikes. Weight is in running order in kgs.  Might help to explain why some can, and can't go around corners fast. Hope you enjoy. Cheers Hutch.
              Name                                     Model:-               Ground Clearance in mm             Lean Angle Left                   Lean Angle Right              Weight KGs
    Sportster:- Superlow                             XL883L                      100                                           24.4                                    24.7                         260
                       Iron                              XL883N                      120                                           30                                       29                           260
                      1200 Custom                    XL1200C                    110                                           28.3                                    26.2                         260
                      48                                 XL1200X                     100                                           26.1                                    27.8                         260
                      72                                 XL1200V                     120                                           29.8                                    28.6                         253
    Dyna:-      Street Bob                       FXDB                         120                                           31                                        30                            305
                     Superglide Custom           FXDC                         120                                           30.9                                    29.5                            310
                     Wideglide                       FXDWG                     100                                            31.9                                   28.4                             310
                     Fatbob                         FXDF                         125                                            31                                      30                               320
                     Switchback                   FLD                             110                                           29                                       29                               330
    Softail:-     Standard                          FXST                          159                                            35.5                                    34.2                           317
                     Fatboy                           FLSTF                         130                                           27                                       26.2                           330
                     Fatboy Lo                       FLSTFB                      125                                           25.2                                     25.6                            330
                     Deluxe                            FLSTN                        113                                           26.7                                     25.8                           330
                     Heritage                         FLSTC                         131                                           25.9                                     24.4                           341
                     Slim                               FLS                             114                                            24.9                                    24                             318
                     Breakout                        FXSB                          120                                             23.4                                   23.4                            322
    V-rod:-     Night Rod Special               VRSCDX                     115                                             32                                      32                                302
                    Muscle                          VRSCF                        105                                            32                                      32                                 307
    Touring:- Road King                          FLHR                          145                                            31                                      33                                  368
                   Street Glide                      FLHX                          125                                            29                                      32                                  368
                   Road Glide Custom            FLTRX                        125                                            29                                      32                                  380
             Ultra Classic Electra Glide         FLHTCU                       150                                            31                                      33                                   413
    You should really have another column to factor it that the only bike that doesn't handle like wet shit on the bottom of your shoe is the Dynas.
    Man you have a good memory...lol.
    So the Softail standard should be the best handling bike out there if your theory holds !!
    oneball, that's sort of what I was hinting at !!
    Now my FXDX, that has around 35 deg' lean angle and 150mm clearance, and I can still scrape things !
    But it does handle very well !
    Odd that the old road king scores well fir both clearance and angle! That's deceptive!
    I'll stick with the good old FXR...
  • TJU
    TJU
    Gidday FLHuTCHu ... am i right in thinking those figures are in Millimetres and does a Softail realy have that much more ground clearence and lean angle over a Dyna ... very deceptive arnt they ... it`s allways interesting to see someone put some time into their post .
    Tim .
    Thats right Tim and thanks for the recognition. MM it is, (i added it to the line just now). I should point out that these figures are unloaded with no rider. So each bike will have a reduced clearance and lean angle based upon the weight of the rider. But to compare apples with apples, say a 80 kg rider should theoretically be able to corner harder and faster on a Softy standard compared to the same rider on a Fatbob for example, BUT the suspension is better on a fatbob and can be made stiffer, where as the softy is more compliant and has a softer setting. So the FXDF would probably have the advantage.
    My personal ride, FLHTCU has the most clearance, and is the heaviest bike out of the bunch. I can pump up the shocks and make it stiffer which is good two up when full of gear but too hard when empty.
    I can regularly round up other bikes fully loaded and stay on the arse of other standard bikes around bends as it has a great lean angle too.
    I love staying on the tail of the odd mate who thinks the granny glides are slow around bends, me two up and loaded pushing around 670kg all up, Them single on a rocker c for example weighing in at 430kg all up, and i always have to brake into and coast around corners as not to hit them and they just cant lose me. It's good fun.
    ( Disclaimer time! I'm not a speed demon, I just like to give it a bit when the situation allows and is right. i'm not picking on Rocker fans, it is just one example. and Yes people i know some riders are better than others. Plenty could out ride me on all sorts of bikes, But this is just my example of what i know as i have had a Heritage, Fatty and a Muscle to boot.)
    Point is in this particular example that the tourers don't have to be slow around bends, they have the clearance and the good angles and the adjustable shocks and are just more comfortable at cruising speeds IMOP.
    By the way i have scraped the on the left three times now but never on the right. One day!............
  • TJU
    TJU
    Bugger ... at a 140 Kg`s , there goes my ground clearence , Lol ... ahh but i`m still enjoying it with every new day i get to ride the new girl .. { bike that is } .. thanks again for the info .
    Tim .
  • Geoff3DMN
    Geoff3DMN
    I wonder how much clearance the XR1200 has...
     New 2013 FXSB Softail Breakout added to table above.
    Also bike weights in running order, fluids and fuel added.
    Well it's always good to have good info,
    but the way things are these days ( speed camera's all over the place & cops ) its not hard to keep up on anything. i'm forced to ride at part throtle all the time.
    the weight is important too, the new Harleys get bigger motors but if weight goes up, that effects handling and performance. i had a 98 cubic inch kick start only shovel & put it on the scales at the track 545 pound wet  bloody thing still goes but my mate put an electric start on it 6 speed box & rides sydney to sunshine coast & back regular ( once or twice a year ) plus it ran 11.7 114mph quarter mile still runs 11.9 with my mate on it  no imission control on that model eather. i did 1 million k on it from new, he is still trying to wear it out ( but just freashed the motor up )
    my old 01 dyna lost some weight, weighed in at the track at 598pound ( carb model )
    how do you boys wear Harleys out so fast?
    I hit 29.5 that hard yesterday it ripped my foot off the peg .
  • Maxiboy
    Maxiboy
    Lean angles were the big shock when I got my Deluxe (first Harley). Coming from Jap bikes the first few corners scared the shit out of me. I have had to modify how I ride so I don't scrape all over the place. Not a bad thing since it slows you down a fair bit, plus the thought of coming into a corner too fast and dropping my baby is unthinkable.
  • scotti
    scotti
    The new 09`up tourer frame , swingarm combo really has to be experienced to be believed , great ride !
  • scotti
    scotti
    I read that the new breakout has apparently got a revised suspension mount or something , which they say is a handling improvement and may be used on all future softies , Oh yeah great thread , well done Mr TChU !
    Thanks Scotti. Just doin my bit. There is a lot of great info on various subjects in here. That why i like this forum and i'm on it most nights.
    I will add the new street bob limited when i get its details.
  • Bloke
    Bloke
    My favorite Harley
    Solid mount Sportie XL1200S 97 to 03 I think -  36 and 40 degree lean angles, Ajustable Suspension for rebound damping front and rear plus Buell Lightning twin plug Heads.   Twin Disc front end with later models getting 4 piston calipers.
    Its a blast in the twisties with the skirt in the breeze
