Online: Soapbox2627, Hilly
Hiding your handlebar wiring.
  • 06 Softail
    06 Softail
     Hi guys, I've been contemplating cleaning up those unsightly wires on my handlebars.  Just wondering how to disconnect the wires from the front blinkers. I don't want to have to cut and rejoin the wires.  I don't care how long it takes me to do it, I just want it to be as professional as it can be. I've done a little search on the web, but most of them just cut the wires. Any tips disconnecting the switch wires, are their any plugs to disconnect? The bars already have the holes provided for hidden wiring.
    Cheers in advance.
  • Cartoon Head
    Cartoon Head
    Tank off and using a wire terminal tool (approx $30) to remove each wire from the connector then you will need to route the harness through the bars and reconnect.
    Doable, tedious pain in the ass of a job but the right way to do it, if you have the patience.
  • Ando
    Ando
    Mount ya indicators onto ya top triple clamp
    Indicators look shit on ya handle bars
    Not the best pic
  • 06 Softail
    06 Softail
     Cheers for the comments so far guys, I've got plenty of patience, so it shouldn't worry me.
