Online: baldy1450
servicing
  • shane059
    shane059
    Hi all, Im new to the forum and am wanting to know if anyone can recommend a place to have my 2012 Street Glide serviced in Melbourne? This is my first Harley and my old mehanic only does Triumphs.I'm in the western suburbs but dont mind traveling if it means getting a good job done,
    Thanks
    Geoff Hucker, Factory Trained and one of the best 0407 523 192
  • GT 1200
    GT 1200
    Well that was easy. So I will try, Looking for suggestions for a workshop north of Adelaide??
    Heard good things about Bikeworks and have used Pro Stock before, but they have move down south.
    Does anyone know if "Ray's Cycle Shack" is still available? Was going to check them out.  Cheers GT.
  • terroristone
    terroristone
    i do servicing and mods from home, i've been qualified since 94. If your interested PM me. Sometimes it hard to get to the shop when you work the same hours as they do. I'm usually available on weekends.
    Regards Andrew - T1
  • jocky
    jocky
     rays cycle shack is still there,ray is agood bloke to talk to and will give you the time of day
  • GT 1200
    GT 1200
    Thanks Jockey, will ceck it out.
  • scotti
    scotti
    G`day and Welcome Shane , Cheers
  • Canetoad
    Canetoad
    Found Geoff Hucker of Hucks Performance Garage easy to talk with and does a greate job, will do whatever you want and gives sound advice. I have used him for my last two services and some extra work. I would reccomend him anytime, plus he is very reasonable with pricing, has an ABN, Harley trained and works from home in werribee .
    In the Craigieburn area is Jason of JDC Customs, he works soley on Harleys and also knows his stuff 0415 384 319, he is also better priced than HH (though who wouldnt be I guess)
