Online: Soapbox2627, Hilly
Carbon Removal
  • jrodgers
    jrodgers
    Hi all,
    Just wondering if anyone knows of a product that will clean away carbon from the top of  the pistons without having to pull the engine appart.
    I have heard their can be a build up and i thought it would be a good idea to give the pistons a clean just incase.
    Cheers.
  • Colstah
    Colstah
    Do a search on Subaru upper cylinder cleaner, and also "Seafoam"
  • Mrjhodges
    Mrjhodges
    So maybe run the Subaru Upper Engine cleaner through (Makes a shit load of weird smoke. I remember seeing them do it when I worked for Subaru) and then change go for a ride, then change your oil to clear the contaminants.
  • jrodgers
    jrodgers
    Thanks for the advise I will look into it.
