Online: Soapbox2627, beaglebasher, baccalaureateclasses, Hilly
How much oil in your forks?
  • fastapastor
    fastapastor
     I looking at changing my fork oil. Dyna superglide 49mm forks. What grade oil and how much per leg?
  • Retroman
    Internet search time mate. Harley don't give you "an amount" for that model , you're meant to "dip-stick" the forks with a special tool which they won't sell you.
    I rebuilt the forks on my 2006 Dyna ( same forks !) and found the "millilitres figure" on the net way back then.
    Sorry i didn't keep a notice of the amount.
    Remember it's a complete forks off the bike job on a Dyna , unlike a Softail which has a drain plug at the bottom !
  • fizzicist
    fizzicist
    Depending on your year - The Wide Glide manual for 2006 Dyna states 112mm & apx 787cc of oil.
    112mm is from the top of tube to the oil with the spring out and fork fully compressed.
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=24&postid=313846&view=topic
  • Retroman
    " 787 cc " , yeah , that'd be about the amount !
    No wonder I didn't remember the exact number FFsake haha !!
  • fastapastor
    fastapastor
    Umm this is my Internet search.
    So for 787 of what weight oil ?? I think you can go a tad more oil with 5 weight fully synthetic oil. I've changed fork oil before and know the drill. Just after some experience for this site. 49mm forks 08 dyna.
  • Retroman
    I used 15W Castrol , easily available in K-mart on the "15% off day"
    Worked fine for me , and i've used it since on Softails as well.
    "The drill" with your Dyna is wheel and forks OFF THE BIKE and turned upside down and " pumped "
    It's quite a palaver although not hard , Softails remove the drain plug , pump into container , refill from the top , nut back in !
    The fork top nut on your Dyna also pre-loads the spring so be careful there or it'll hit you in the chin !
    Loosen the nuts while still clamped in the triple trees and re-tighten them once they're back in the trees and the wheel / brake etc is all in position and correctly torqued.
    In my Official HD 2006 Dyna service manual ( I've still got it !) it DOES NOT GIVE YOU an ml amount !
  • fastapastor
    fastapastor
     Cheers retroman. I'm thinking of motul 5w full synth. With a few more mills. Fast moving oil with the bit extra to keep it firm. Mate did it and worked great.
  • mongrel
    mongrel
    Just a heads up - your volume of oil sets your travel - measure your travel with out oil or springs in, top fork cap removed put cable tie on forks & compress forks should be about 120-125mm add your oil amount . When back togeather & on bike , go for ride & do a few stoppies [front brake only] remeasure to the cable tie .If you want you can take your fork cap off & using a syringe add or remove oil to suit .I removed 50mm at a time I had to do this because I put Works triple rated springs in & emulators plus drilled out bleed holes in forks.My fatbob takes 700mm of oil & I have 120mm of travel ,5mm to spare .Hope that helps ,the weight sets your reaction- light oil faster -heavy oil slower .
  • fastapastor
    fastapastor
    Thanks mongrel that's just the refresher I needed. Cheers
  • mongrel
    mongrel
    I forgot to mention that I've got wideglide forks in my fatbob 60mm longer then fatbobs & are at a good price from Harley Davidson about $120 a leg ,the first set I bought from states were just show chrome set ,scratched & marked easy .At the moment I'm running trans-oil in forks -no problems.I have done 93000klm & I still do adjustments & tuning ,but I know my bike will stay in contact with aussie shit roads at any speed & fast cornering
  • fastapastor
    fastapastor
    Tranny oil !! Alright. That'd work. I use it in my primary.
  • mongrel
    mongrel
    I'm not sure about using tranny oil in primary I would think it's a bit light .I have been using what I use in motor, but for last 3 primary oil changes I've been using straight sae30 engine oil instead -no problems . I though the Syn oil I was using was a bit expensive and a bit of over kill .If It works with no clutch slipage or no iron fillings stuck on magnet drain bung all should be good. Good luck
