Sporty seat
  • DAVUTCH
    DAVUTCH
    Lookn for ideas on sportster single seat cause the standard one is ok for short trips but lookn for something for those long trips which is softer on the arse
    PLEASE HELP   IDEAS
  • scotti
    scotti
    Mustang Seats , extensive range and styles , quality second to none , comfort that needs to be felt to be believed , worth checkin out their web and clips , they make the OEM seats look and feel real cheap , was free shipping too !
  • scotti
    scotti
    Also the more ya ride , the more ya butt gets conditioned to any seat , should also check out the airhawkes or American Motorcycle Specialties gelpads !
  • Fatman
    Fatman
    Agree with the mustang seats. The stock seat is crap if going to do long rides. If 2-up, can't go past the HD Sundowner deep bucket touring seat. With a decent seat & continual riding, you will find that you will not need an airhawk, (although they can assisst in the interim), as the arse toughens up.
  • ireland
    ireland
     I have a Corbin Hollywood solo very comfortable also has a lock on it got it from forum sponser Vpw in Epping very happy with it
    look @ the suspension ?
  • Wimbo
    Wimbo
    Yeah, the arse looks right up.
    Maybe if you can, drop the bike down a bit at the rear and get a Mustang.
  • Normthe1
    Normthe1
    I fucked off the standard seat on my Iron mate and put a Mustang Vintage Solo on, never looked back. If you have 3kg of arse crack to drag around like me, then I can definitely give it the thumbs up...
  • DAVUTCH
    DAVUTCH
    thanks guys already got suspension lowered etc ,will look at mustang apprciate the help
    again thanks
  • scotti
    scotti
    No worries man , did ya check out their website , best thing i ever bought hey , great to deal with also !
    these models are already low i mean raising it up to normal sporty spec with good brand shockies  & normal sporty lenght fork tubes  & good set of spring etc , the lower you go the less shock travel & the harder the ride. low looks cool but is shit too ride
  • Wimbo
    Wimbo
    Thats not low.
    This is low.
    What do you think DR?
  • 666
    666
     yeah iam looking at the moment for a seat, drag specialities. mustang ,c&c customs just to name a couple
    i think i seen that bike before
  • 883n Harley Convert
    883n Harley Convert
    I've got a bare bones and its great, had a similar issue with the brawler seat and got rid of it. I had a 48 seat that was kinda uncomfortable on long rides but would be keen to get some feedback on the Mustang seats. supposedly, they're brilliant.
