Online: Stuart
cam set
  • ray908
    ray908
    Hi I was just woundering does anyone know of a good cam set for my 06 fxdwg I would like abit of a rough idel aswell my mods are se pipes se air filter and a se pro tuner cheers.:
     Ray, bit hard to say, but think more compression & a cam would be the go for what u want, as just a cam on own will lower your cranking pressure & make it a bit softer @ idle
  • speed
    speed
    Hi ,i put 211,s in my 88cu and it made a big difference ,i then fitted a 95cu kit ,10.25 to 1 hi comp pistons and had a heap of head work done by the hallam boyz in victoria, the fuckin thing flied ,its 93hp with 100lb/ft torque, the point i,m getting at is that 211,s will work ,you can also use S&S 585 ezy start cams ,they will work fine
  • pat
    pat
     I had Woods tw-555
    made for stock heads and ccompression ,very pleased
  • pat
    pat
     I had Woods tw-555
    made for stock heads and compression ,very pleased
    A set of these 18404-08 pushrods
    Pr of bolt cutters ..............................................
  • the_mongrel
    the_mongrel
    I love my Andrews 57H :) Great idle and pulls nice!
