Online: Stuart
Harley Newbie needs guidance... be gentle
  • imoo6170
    imoo6170
    All Harleys sound and go like a Harley, especially if you have replaced the std pipes. Pipes are cheap compared to the bike so if you find a good deal without the pipes go for it - maybe even use that as leverage to bargain down the price. As for Wide Glides / Superglides / any other model, it is a personal choice - really depends on your own personal preference - all Harleys are great !!!
    As for making them go better (which we all want to do) check out this site http://www.harley-performance.com/stage-1.html - It is as an example overview only - there are millions of sites about hotting up harley engines.
    welcome to the forum and good luck in your search - ps take your time and do the research before you buy - buyers are ruling the market at the time being so there is no rush...
  • Filthy
    Filthy
    Pretty sure up to '05 were carbies and later EFI. Displacement would also have changed, along with an extra cog added during the period you are quoting. IMportant considerations for performance and any later modifications you might plan.
    Good luck with the search.
    Philthy
  • hogpooh
    hogpooh
    go for a 96 inch or later(07). 88s had some bearing issues when km got high plus you will want the 6 speed box. are you regually takin a partner? then a superglide could be a little small. softail standard or custom excellent bikes as is wide glides
  • Sparra
    Sparra
    There's a shmick looking 2010 widey in the classified's...Might be a page or 2 back...
  • scotti
    scotti
    If ya lookin for swagger , purchase a Bagger , more bike for ya bucks !
  • 06 Softail
    06 Softail
     It's been said before but I will say it again, take as many bikes for a test ride, especially with your partner. You will find the bike which most suits both of you and is most comfortable. Ask as many questions as you need to & take your time making those important decisions. Maybe book in for a ride day @ your local or nearest HD dealer. Good luck with your search, and happy riding.
  • GT 1200
    GT 1200
    A couple of days research and looks like he's gone? Back to 0 posts.
    Maybe changed username, maybe changed his mind or the missus said NO !
