Starting problems 79 Ironhead Sportster
  • xlh1000
    xlh1000
    Just wondering if anyone has any suggestions re a problem Im having with the electric starter on my 79 Ironhead. Battery tests out fine (by battery retailer). Symptoms - One loud click every time starter button pressed, after about 5 trys starter motor will turn over and engine will fire. I have cleaned every contact from battery to s/motor incl solenoid. Could this be a solenoid issue or is starter u/s?  Thanks.
     use a test light to the solenoid the small wire if it lights up when you press the botton  the relay is good  , then test the main for the solenoid to the starter if this doe's not light up then it's  the solenoid ,  if it doe's light up its the starter motor
  • xlh1000
    xlh1000
    Thanks for the advice i will do the test and let you know cheers.
