259e cams
259e cams
dv8
I have SE 103 street stage 4 kit with 259E cams, they pull hard from 3000rpm and up. I have just ordered a set of T man 625 cmas, as they pull from 2200-2400 and upwards. SE259E cams are good, I just want the torque coming on lower in the rev range.
dv8
Bike pulls well from 2000 rpm, not a slug by any means, ( in first 3 gears) really feel it at 3000rpm. I find in 4-6, really need to be around 28000rpm - 3000rpm, otherwise bike doesn't really like it, valve/train noiser and bike feels if it is struggling.
BlackRk103
Could the Struggle be tuned out or doesn't require a bump in compression/ head work to sort it.
dv8
The stage 4 kit come at 10.5 -1 compression. changing V&H staggered long shots to V&H pro pipe and the Tman 625 cams. Torque should be lower and why I want it more. Also taking SE110 heads off and getting 96" stocks ported, valves and springs done. Should come on strong all way through, hopefully, will see next month, when parts arrive and get installed. Nothing wrong with the SE259E cams, just trying something else and see how it turns out.
Ando
What ya gonna do with the heads you are taking off????
dv8
they are the SE110 heads, not the MVA one. not sure, will sell them when i get the 96' heads installed, not for another 6 weeks or so. waiting on parts still.
Ando
Let me know about the 110 heads
dv8
Exhaust has arrived, heads going in next week, will let you know about SE110 heads if you are still keen in a couple of weeks
