loan or hire of cam bearing removal/install tool
  • Daggs
    Daggs
    howdy all,
    I'll be doing the S&S 106 big bore kit i have sitting in my workshop and cams (probably S&S 583 easy starts) some time in the next few months.
    So I was wondering if there is someone out there willing to loan (or hire if they want) inner cam bearing puller / installer when I am ready?
    Bike is 2008 Street Bob, 96 TC.
    PM me if you would rather reply that way.
    Cheers !!
  • Daggs
    Daggs
    really? no-one.... you could even charge a bond then pay it back when tool is returned...
    oh well, i guess I'll get my own then offer to hire it out
  • Sparra
    Sparra
    Hey Daggs...there was a post on here a while back from a fella that had bought one and said he would hire it out if someone needed one...Can't recall who it was but I will keep looking...Surely someone has one that they could lend you...
    Cheers...Sparra
  • Daggs
    Daggs
    Cheers Sparra, I'm not ready for maybe another month, just thought I would start asking around.
    Not a big deal I'll buy one if I have to
  • Daggs
    Daggs
    No probs Hilly, yeah I am a top bloke !
    I'll check out your suggestion
  • taff60
    taff60
    Sorry mate, I havent got one, but i just used a blind bearing puller that i got on fleabay. Install was a case of bearings in the freezer and use the old bearing to drift it back in. Surprised me how easy it was.
    If all else fails, you can get them on ebay for about $90 landed.
    Hope this helps.
  • Daggs
    Daggs
    Thanks Taff, yeah I know they can be done that way but would like to give the proper tool a go and yes watching a couple on fleabay !
  • AJ56
    AJ56
    Didn't Hmmm2 do a cam change not so long ago... I am pretty sure he was chasing a setup as well and got it sorted.
  • Colstah
    Colstah
    Can't help with that tool, but if you need a puller, this guy would be worth a look - http://www.georges-garage.com/tc_engine_2.htm
    I recently got a steering head bearing tool from there, much cheaper (even with delivery to my door) and only took 8 days over the Christmas period.
