02 Sensor location
  • ozymax
    ozymax
    PowerVision  Auto Tune Pro requires WIDE band 02 sensors 18mm to be installed.
    Standard ECM needs narrow band 12mm sensors for closed loop..
    Current pipes and I suspect most after market pipes for current bikes have 12mm sensor bungs fitted
    Is it ok to have both permanently installed?
    How far apart should they be to prevent flow sampling issues?
    Is there a preference to have either one above the other? ie wide band closest to the port or narrow band closest.
    What happens if they are the opposite way around in each header pipe?
  • ozymax
    ozymax
    Kohls or Keefer ??
  • pottsy.r@gmail.com
    pottsy.r@gmail.com
     let us know if you get any info ozymax i am thinking about fuel moto big bore kit with fuel moto level b heads and power vision auto tune on my bike theres only really one place for wide band auto sensors thats with d&d lowcat pipes
