Air filter suggestions / advice for iron
  • Urban Guerilla
    Urban Guerilla
     Hi All,
    I'm looking into a new stage 1 air cleaner rather than the Screamin eagle stage one (think it is anyways) ,stock sardine tin looking thing.
    I'm thinking of an S & S air cleaner with newer style teardrop in wrinkle black, but also considering a performance machine mesh front.
    http://www.ebay.com.au/itm/140781888691?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648#ht_1641wt_974
    http://www.ebay.com.au/itm/390532754200?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648#ht_2598wt_907
    Both appear to have higher flow of air, and look good. Other than that, I'm shopping for input.
    Thanks in advance
    P.S it's gotta be black :D
  • IR0N
    IR0N
     Yeah cant go passed performance machine gear!! top shit!
    I run with this one on mine and im very happy!
    Also if you are going to fit this your self, you may have to turn the idle down after you fit it and if you dont know already its a 5 point pined Torx screw (sorry i forget the size and the standard Torx screw is 6 point so dont get caught out!!) but make sure you have one of these its the only way to adjust it. Other then that just go with what you want PM or SS its all up to you but i think the PM would be better flow and looks better
  • Urban Guerilla
    Urban Guerilla
    whoa Iron!
    Thats a pretty serious looking piece of kit. Thanks for the feedback man
