Online: Stuart
Having problems with rear sprocket,, Rigid Shovel
  • Slick88
    Slick88
    Hi Guys
    Rigid Shovel
    Chain drive
    Just got new steel spoke rims
    Have rear sprocket with offset that bolts to hub
    Using high tensile bolts through sprocket with flat washer and Nylok nut on hub side
    The bolts seem to be stretching
    After a short ride find that I am having to check and re-tighten the bolts
    Had this problem in the past when I had alloy wheels
    Eventually  the bolts would come loose and then shear off and on the second time destroyed the hub to the point it was not repairable
    The previous set up had flat sprocket with spacer.
    At a loss to how to rectify the problem
    In outer eastern  Melbourne suburb of Croydon
    Any assistance would be most appreciated
    Even better should there be an old school chopper guru in the area that could maybe pop in and have a look then happy to make sure they go home full of beer, whiskey or wine
    regards
    Slick (Ron)
  • ozymax
    ozymax
    is the hub counter bored for the bolt shoulder?
    +1 ozymax make sure the centre spiggot is a good fit  not oversized ,     they should be 5 X 7/16" bolts  grade 8 or allen bolt's grade 12 with good nut's,     white nylon locknut are soft  get good steel one's  sounds like the threads are pulling  , just do them up untill there very tight if they pull there threads they were no good anyway , but always check sprockets nuts on servicing
