2006 Softail Thundermax
  • Daveman
    Daveman
    G'day,
    I hope someone can help me, I have 2006 Softail Standard 88B. I have Big Radius 2 into 2 exhausr and i have just installed a Screaming Eagle Heavy Breather and Installed the Thundermax Autotune.
    I cant find anywhere in the base maps anything close to that configuration, ive done firmware updates but no change, can someone help me with what to do next.
    The choices of exhaust etc on the basemap settings when i begin the sequence dont seem anything close to what i have.
    Cheers, Dave
  • Will67
    Will67
     if your exhaust is not listed its not an issue you just select the closest type for exaple; the video explains it also at 2 min 12 sec into the video.
  • Daveman
    Daveman
     Cheers will. The video didn't say the bike will run like a pig till iac auto smoothed it out. I spoke with zippers and they put me onto a good start map.
    Thanks for your response
  • MJ
    MJ
    i had one but in the end it had to many issues so junked it
  • Daveman
    Daveman
    Had it on the bike for a while now, done a few hundred Kay's on it. Still runs rough when I'm holding speed between 40 and 90 kph. Under excel its beautiful. Should I run it through the auto tune again so it can adjust at what it has set itself to now or will that set me back to square one?
  • MJ
    MJ
    Just keep riding it will sort it all out
  • Rocky2010
    Rocky2010
    I have a 2010 Fatboy Lo and have had a Thundermax with Auto Tune since I purchased the bike with over 40,000ks on this bike now I have never had and issue with the tune on the bike. It runs well I couldn't be happier.
  • jungle
    jungle
