180 tyre
  • Blackbob
    Blackbob
    does anyone know if the dunlop is the only 180 tyre that will fit a dyna or are there others
    Blackbob
  • Hicksy
    Hicksy
    G'day Blackbob,
                                 My new wide glide has a Michelin Scorcher on it. Hangs on good.
  • Blackbob
    Blackbob
    do you have blinker stems that take the demountable stuff i wanna put a sissy bar on me bob also?
    i know ya can get em but i cant find em
  • robots
    robots
    hi,
    i got the dunlop gt502 on the wide glide which I understand is the SE 180 tyre kit, got 14000kms on the original, probably could of got another 1000
    ended up getting peter stevens geelong to put another dunlop gt502 (genuine HD tyre) on, I like the width, I cant tell if it is a superior handling tyre as I do mostly freeway/country road cruising, I keep the pressure at about 40-42psi cold
    have an avon venom 90/90-21 on front, has 10000kms on it and still looking good, maybe get to 20000kms with it,
    thanks
    robots
  • Blackbob
    Blackbob
    Thanks for the reply's
    i got the relocation kit fitted just need to decide on the tyre.
    think i'll be goin with the scorcher
    Blackbob
  • christoff
    christoff
    the scorcher is a really crap tyre. go an avon or metz and suddenly yr goanna understand what crap they really are.
  • linmac
    linmac
    I've just come up to 10,000 klms on my wide glide and the scorcher has been a good tyre but both the front and rear are ready to be replaced at the same time great.
    I've been looking at a few options but there is only a choice of five tyres for the back
    but what I did notice is if you drop the size down to a 180/55 17 there is a lot more choice there cant be that much difference between 180/60 17 and 180/55 17
  • robots
    robots
     Hi llinmac,
    i gonna try the Dunlop d407 or commander 2 on the wg next, the d407 a little bit harder but also slightly deeper tread from what I can ggather
    have Avon 90/90-21 on front and after 15000kms still going good
    thanks
    robots
