Rear number plate fitment on Street Bob 2013
  • Divorced
    Divorced
    Anyone doing kits to tidy up the number plate on 2013 Street Bobs ? would like to side mnt it but dont want any heat from the po po's dobnt really want to drill holes in my guard ..if not may just Fab somthing
    Leavin mine as is...
  • deceptive
    deceptive
    there's a guy on another forum that did'nt like the factory side mount so custom made a rear mount. might give a idea on making one to tidy it up http://www.hdforums.com/forum/dyna-glide-models/845862-shop-built-license-plate-relo-2013-street-bob.html
  • Plonky
    Plonky
    I didn't like the the plastic that was mounted to the rear fender holding the number plate so I purchased a side mount from Kuryakan. It said fit straight on but turned out that was not the case. Had to mill it back about 6mm but definitely looks better.
    Also the plastic moulding couldn't take out so I got it cut flush with the fender.
  • Plonky
    Plonky
