Just bought a 88 softail an cant get it started!!
  • SlickRick
    SlickRick
    Hi guy's i just bought my first hd and finally got her home an have been riding it any chance i can get thoe were in the middle of moving hous an the miss isnt too happy with me buying the bike any way this is the story i was in the middle of moving house an was dropping shit off at the new place an the miss was at the old place so i thought this my chance to go for a quick ride so i jumped on she started first pop an had the choke on an before i got out of the garage the miss called  my phone so i quickly switched her off an havn't been able to get it started properly ever since, I have tried squirting start ya bastard in the carby an it kicks over straight away but wont keep runing so im thinking its probly flooded or somthing but any tech help would be greatly appricated.
  • Soapbox2627
    Soapbox2627
    rip ya plugs out and clean them.
    use the fuel enricher (choke) as little as posable, pull it out start the bike get some revs and push it back in, hold the revs with the manual control (wrist)
  • scotti
    scotti
    Ask ya missus , think of it as quality time , just remember to duck hey , jus kiddin man , yeah sounds flooded like ya said , check or change fouled-up plugs maybe ?
  • SlickRick
    SlickRick
    thanks guys got it sorted today used start ya bastard an it kicked over an took it for a thrash an it poped an farted till the fuel burned up,but no im not aware of the reverse position on the tap i only switch on when i start it up an off when i have switch it off?
    Usually if I flood something I turn the throttle all the way round and then try to start it. Seems like it would do more harm than good, but it seems to work. Now someone needs to tell me I'm wrong :P
  • ozymax
    ozymax
    yep bonkerz thats the go. full open = more air
  • SlickRick
    SlickRick
    Thanks guys ill keep that in mind if it ever happens a again she runing sweet now!!..........now just need to work out what to do with ugly paint job and can any one reccomend any good bike painters in adelaide?
  • coffee guru
    coffee guru
    Atleast youll be able to find your bike easy on a group ride stop!
  • ozymax
    ozymax
    you could look in the parts for sale section
  • Colstah
    Colstah
    In my experience, the symptoms you describe when you did get it started could be fouled up plugs. My stock 94 can only stand to have the enrichener (it's not a choke, doesn't work the same) for a very short time. As soon as it starts, I put the enrichener back in and warm it up with careful throttle control. If I use the enrichener too much, my plugs are black and sooty, and it takes 4 or 5 clicks before she runs smooth again.
    (I know, Badcooky, probably running too rich, I'm gonna look at that soon!)
    As for the paint, not sure if I'd pick that if I had my bike painted, but it looks good enough that I'm not sure I'd be in a hurry to paint over it...
  • rider
    rider
    Bunnings sell lots of black paint in spray cans !
    I've always had black bikes (Harley's anyway), but I wouldn't break my bank to change that color either...as least not straight away.
  • SlickRick
    SlickRick
    has anyone sprayed a frame with the motor still in it?
  • scotti
    scotti
    Much bigger and more exxy job man , if ya don`t mind that blue just do ya tins and fuck the celtic flames off hey , not that it looks that horrid or anything , just bright , nice ol`ride SlickRick !
  • SlickRick
    SlickRick
    Thanks Scotti, ive decided to keep the blue it looks better in person its that xr6 blue, im thinking whit flames on the tank with hd logo an the front an back guards just blue.
  • scotti
    scotti
    Yeah that`s much better idea i reckon , me nephews is similar colour with real faint , silver ghost flames , looks trick !
  • simmac18
    simmac18
    Mate what size rear wheel have you got is a a 180 or 200?
  • SlickRick
    SlickRick
    200 rear simmac
