2008 Top End Speed
  • TJU
    TJU
    Guys , have also posted this question on the Softail section but was wanting peoples advice on what they thought a 2008 Fxstc  comfortable cruising speed should or could be .
    Still have the restrcitive stock  pipes and  aircleaner on and soon will be replacing both as well as getting a remap but am a little dissapointed in the crusing speed of the new beast ... from zero to 90 or 95 no problems but pushing it to 100 and beyond really seems to be putting a lot of unwanted pressure on the new girl .
    Had only 1200 K`s when bought and only done about 500 K`s these last few weeks so i realise it is still pretty tight but surly a 96 cube bike should be able to handle a 100 K`s or more ... i have had other brand bikes in the past that have flat spots in there rev range and was thinking this may be the case as it does seem to free up a little above 100 but dont want to push it and do any damage .
    I do come from a Jap bike back ground of late and i dont expect it to rev like one of them but Jeez this thing is nearly a 1600cc engine ... am i expecting to much or are they that resticted and will it be a considerable difference once the new pipes aircleaner and remapping is done .
    Thanks for any advice and idears ... Tim .
  • GT 1200
    GT 1200
    You might have to try the rest of the gears?
  • Derek.1966
    Derek.1966
    Should be good for 180 kph.Preferably not in a 60k zone.
  • FLSTC
    FLSTC
     it may be 1600cc's but its a V twin, air cooled motor so the sweet spot is closer to 3000rpm NOT 7000rpm on a sports bike.  ( give or take )
  • scotti
    scotti
    Should still pull at 170 at least and stretch it to 190 without any worries , what has been changed on it ?
    Something don`t sound right ?
  • Gonads
    Gonads
    Stay out of top gear until $1.10+. I dont use 6th unless steadily doin over $1.20. Will easily cruise all day long on $1.40 and regular bursts above and beyond that. You may need to change your riding style.
  • Daggs
    Daggs
    with only pipes and air cleaner changed plus tuner an otherwise stock 2008 96 will do well over 200 but it sure gets hard to hang on !!
    at 100 im usually still in 5th or maybe just in 6th but its almost labouring in 6th at that speed. much happier at 110 - 140 in 6th
  • Crazy Erny
    Crazy Erny
    Hey new Bro, I have an 09, FLSTC & while they are a heavy bike, you should have no trouble powering up from 80klm in 6 gear all the way  180klm +. Something is definatly wrong, best advice is to take it to a Harely specialist (Not a Harley Dealer) & get them to take it for a ride & get their opionion! Sounds like it could be running lean or the timing is too far retarded etc. Don't ride it too much until you get it checked out. Let us know what it was. Mine loves to cruise from a 110 k to 140k where it just sings all day, every day without any stress.
    PS. A nasty thought is that the motor could have been cooked & seized by a previous owner, I hope not!
  • TJU
    TJU
    Thanks for all the advice guys ... have a few things to look at now ... for one i will stay in 5th a bit longer and as a few of you said it should be good for a hell of lot higher than what i have had it .
    Had a old 76 Shovel back in the late 80`s and that was good for well over the 120 mark especially once i got the gearing sorted out ... that was my first thought about this one as it is really good down low but not so good up higher ... i have been changing into 6th gear to early from the sounds of things .
    As far as i am aware nothing has been changed on her apart from the bars and bling i have put on her ... i will definitly have the local Harley guy check her out and i`m really hoping Crazy Erny isnt right about possible cooked & Seized motor by previous owner ... insert crying man here if that is the case , Lol .
    I know i am only going to stew over it until i get her checked out but would a Cooked and seized motor be pretty easy to start and feel real good from zero to 90 ... oil is good , dosent seem to run to hot ... what is a safe temp range after riding for up to a hour or so .
    Thanks again guys and will let you all know the out come ... Tim .
  • Crazy Erny
    Crazy Erny
    Ah shit mate, I didn't notice before, you only live around the corner, you can come around here and give me a look at it, or you can go to the Grunt factory at Yatlia & get Robbo to take it for a spin & evaluation, just ring them first (38077211) & ask Simon (The owner) for the best & most convienient  time to go over!
    Good engine temp depends on time of year, where you are riding & how hot the day is. Around this time of year cruising down the M1 200 / 225 F should be about average. Harley Says that the 96cu twinkies, run safe up to 300deg F But I would pull over at 275deg F temp & let the bike cool down. By the way, what sort of oil are you running in the motor & gearbox?
    PS. Some good advice: Do not do any upgrades uintil you know for sure that your bike is running to factory specs, & again I would hesitate to push it hard through the gears as I have already stated I have no problems excellerating from 80klm to over 160+ in 6 th gear with a pillion on the back. It would also pay you get Bad Cookies advice as he knows his shit, same with Chopper.
    Cheers! C.E.
  • ozymax
    ozymax
    flat rev it in 5th before you think about changing to 6 and see how she goes. wouldn't advise it on the M1 down your way though
  • Robbo_Townsville
    Robbo_Townsville
     Hit the rev limiter on my FXST 2009 in 4th gear the other day and was surprised to see 185 and 2 more gears to go.
  • TJU
    TJU
    Your not wrong Ozy about taking it easy down my way , they sure do like to hang out around here the old boys in blue ... good to hear all you guys letting me know the new beast should be good for a lot more than what i`ve been giving her ... maybe i`ve just been to much of a pussy with her , Lol .
    Hey Erny i know what you mean though about taking it easy until i have it checked out ... will get onto the guys down there you mentioned and see what they think ... when i have it sorted i will let you know how it all went ... have you had any dealings with the guys at Heavy Duty ... only ask as they are pretty close and have got a few little things from there and seem ok but havent had any work done there .
    Tim .
  • TJU
    TJU
    Will do Erny , thanks for that .
  • Crazy Erny
    Crazy Erny
    Cheers Bro, anytime!
  • ozymax
    ozymax
    I understand the guys at HD are quite good and by the looks of the bosses set up on his dyna I would be comfortable letting them work on it.
    You could take it up to Fred at Pro Cycle dyno for a free evaluation run but you will need to book it in he is flat out
  • TJU
    TJU
    Thanks for that Ozy ... it`s allways good to have other options .
  • shingles
    shingles
     a mate is ya bike one of da recent imports dat r floodin  oz ya see HD S sent or made 4 oz av differences from say bike ya may av bort dat was say made an tuned california coz theres bit of difference does ya id plate start wif 1hd bla bla bla coz dem ones made 4 usa market our id start 5hd on plate av look on ya frame see if ya can see stampin of heap of numbas maybe on ya rego 1hd if is da case well u av american market made HD which can make lotsa diff firstly ya dont no wat state was made 4 coz usa has diff fuel restriktions dan ere like say 89octane maxsetup were as ere can av 98 or higher  i use 98 always never use dat low grade shit will run like puss ,now if yor bike was 4 california state well never run propa coz ya motar made 2 use 87 -89 octane now could b part ya prob 2 start wif jus coz not many ks on im seems 2 me kood b 1 dese brought from sum dude usa an resold ere by dese companys all bike mobs doin it so if dem frame start wif 1hd u will not no wat state of usa was sold in u mite b luky an av paperwork from purchase in usa but doubt it u dont no anythin bout bike then coz shop no giv ya papers sayin was bort sum us shop 4 15k new so herin lies ya first step c wat ya got go out look on frame an if saz 1hd well wasnt homologated 4 oz 2 start wif , u no like all dem jap import cars dat people buy sorta look same but not an can or not b trouble ,so firstly look rego papers see 1hd on print well dats first point or if 5hd all is good an ya jus need 2 put highest octane an go out giv another go dont b scared 2 rev dese motors av built in rev limitas so u b ok on m1 5th  110klms 6th 120 odd bike should be responsive as from getgo try twistin throttle more day not like o ill jus rely on tourque not way 2 ride them can do more harm by labourin moter ,listen start riden like ya jap bike dese motors will take it wont rev past 4500 limita cum on but will sound like is revin a lot higher but is not ,there not a plonk plonk plonk sorta moter ya av 2 giv it sum dont b afraid it should b givin u a thrill in seat of pance wheel spinnin even mate cruising speed on m1 4 me 120 min or if ya conservitive rider 110 in 5th u will find this annoyin u b goin 6th 5th 5th 6th remember usa has 70miles an hour limit so gearin not rite 4 here TAKE ALL THIS INTO YA HEAD AS JUS AN OPINION ON ISSUES U WROTE BOUT YA BIKE NOW YA NO Y HARLEY GUYS SEEM 2 B GOIN BIT FASTA DAN LIMIT ON M1 OR WEREVER
  • TJU
    TJU
    Gidday Shingles ... yep it is a import , got a pretty good deal ... it`s definitly not a Californian model , and i know what you mean about the different fuels but i am running only the good high octane stuff .
    I think from what you are saying as well as many others is that i was changing into 6th gear way to early so am definitly going to change my gear changing attitude .
    Have just recently got my Freedom exhaust from the states as well as just this week getting my S & S Stealth air filter and Air Stream cover , so hopefully with those put on with of course a remap then the new girl will run a lot more free .
    My only thought though is wether the IED`S that Retroman mentioned might be a option to look at , from what the PR Blurb says it seems to make sense ... does anyone know if there are there any distributors of these products in Sth East Qld .
    Thanks for the advice Shingles , allways appriecated ... Tim .
  • ozymax
    ozymax
    I tried them and they did make a small difference. However a proper tune was miles better.
    I got them here
    http://www.eastcoastcustom.com.au/
    Brendale
