Softail exhaust
  • Daveman
    Daveman
     Sorry if this has been posted before.
    Ive seen different posts scattered with no clear answers.
    Can anyone tell me what exhaust for softail models makes the best power. Looks do matter but first I want to work on power then decide on looks after.
    i have an 06 softail. Any help would be awesome.
  • Retroman
    A 2 into 1 will make the best power. Most however are well fugly , that's the drama !! Not to mention EXPENSIVE
    Stock HD downpipes and balance pipes make good torque , so use them with a well constructed freeflow slip-on muffler.
    I find Khromewerks to be as good as any , and well priced
    Bonus is , they look EXACTLY like stock when parked up , hard for the coppers to spot them
  • Ando
    Ando
    Buy what ya like the look of
  • Daveman
    Daveman
    I currently have a set of Vance and Hines long radius pipes on the bike.
    Im upgrading the ECM and Air Cleaner to a Heavy Breather and would like to make the best combo available to get the maximum power.
  • Cartoon Head
    Cartoon Head
    Ya cheeky bugga Gregg! My 2 into 1 is as attractive as Angelina Jolie........................well if your blind and a pervert for chrome exhausts lol
    I agree with Ando and Gregg (after seeing a photo of Ando's bike I unashamedly brought the same pipe) buy what you like the look of Daveman although for power 2 into 1 is the go imo.
    On a side note, As HD are low compression I only ever used 91 ron (stock motor, heavy breather air filter and Screamin eagle slip ons, TTS set up by Gregg) and didn't experience any pinging until I put the 2 into 1 pipe on now I have to use 95 ron.
