Online: Wanderer57, Merv
wiring plugs
  • black29d
    black29d
    Hi All
    I have just changed my bars again after dropping the bike trying to get in the door with westerns, too wide for the door...., I have  now put on T bars, much shorter and easier to get in the shed.
    Anyway, while doing the wiring through the bars, I have damaged the plugs, the locking tabs inside has brokern off.
    Anyone know where I can get replacements, or do I have to change both ends to non standard Harley plugs.
  • terroristone
    terroristone
    google deutsch connectors, and find your local supplier.
    T1
  • AJ56
    AJ56
    just go to HH and ask for the replacement plugs...I chased plugs for months when I was wiring a trailer hitch, in the end I rang HH and ordered the plug.
    I'll just throw it out there, try your local HD dealer.
  • IR0N
    IR0N
    I would stick with the deutsch plug as they are almost waterproof, or what i did is fuck all the plugs of and just use the pins and heatshrink.
