penrite 20w60
  • pottsy.r@gmail.com
    pottsy.r@gmail.com
    would 20w60 penrite mineral oil for diesel be ok for harley twincam 103 with 20000k s[IMG]http://i1064.photobucket.com/
    try Penrite ENDURO
    What part of the country are you ?
    My opinion is the 20w60 Penrite would be fine, and I have used it in a 1200 Buell, and a TC.
    D'racer, would you say the Enduro 25w70 would be a bit on the thick side for cooler climates ?
    pottsy.r@gmail.com
     Thanks speedzter got your crankcase and crankshaft back yet oh i am down southcoast tuross head nsw
    they do not hold enough oil  on board less than 3 ltrs esp on the under the engine sump models the oil gets very hot & down spec, drain when her  hot & you will see
  • Robbo_Townsville
    Robbo_Townsville
     Penrite HPR Diesel 20w - 60w was recommended to me by local harley/trumpy workshop for my 2009 FXST.        I live up north though.
  • Alvarez
    Alvarez
    20w-60 diesel is perfect for use in evo and twin cams provided you only want them to last to in excess of 200.000 klms trouble free.............it's a long term marriage made in heaven
  • terroristone
    terroristone
    has anybody tried this in a sporty?
    T1
    I think a Buell is pretty close to a Sporty !
  • 666
    666
     Hey t1 iam running penrite 20/50 mineral for run in on mine will change back to ams at 1000klm check out penrites site good info on there
    T1, I've run Penrite in all sorts of bikes/cars for years. I normally use HPR 10w50 gas semi Syn' in the twin Cam and the KTM 950.
    It's easier to find out in the country, and a side benefit it is cheaper.
    I'm sure HD oil is perfectly fine, but I've never used it, so can't compare.
