Sporty Pulley
  • ozymax
    ozymax
    Is a 68 tooth rear sporty pulley a straight bolt on for the late dynas?
  • ozymax
    ozymax
    cheers Hilly. I don't have any spare pullies to check against. It seems like it should fit, both have the same width belt 1"
    much drama in changing the front ?
  • ozymax
    ozymax
    cheers.
    looked like a bit of stuffing about and may need some tools to do it with out risking damage.
    68 it is then.
  • ozymax
    ozymax
    that would be a nice problem to have to deal with
  • nhb006
    nhb006
    Yes BUT depending on the height of the rear sus, it may cause the belt to just touch the frame over some bumps. I made a spacer for mine.
  • ozymax
    ozymax
    cheers will check that
