New 120ci
    Harley have these motors for $7500- in the spare parts div . Seemed good value until you add throttle body , injectors , breather and a couple other bits , bumps up to $9600- . Approx $1000- to fit , then it all becomes a dream.....
  • ozymax
    ozymax
    and pipes and clutch and tune.
    there's a few guys on here with them or other high end builds
    1 benefit I guess is maybe some type of warantee
    Clutch springs ( clutch bits ? ) were included ( he rattled off a heap of bits for the extra $ ) , but no warranty , as Harley sell them as race/off road only .
  • ozymax
    ozymax
    or you could wait for the S&S 139ish
  • clubbie
    clubbie
    Or wait for the Harley roadshow/sales with 20% discount.
  • GT 1200
    GT 1200
    What's up Tim? need a bit more power hey?
    When too much power is still not quite enough !
  • GT 1200
    GT 1200
    Never enough mate.
  • shingles
    shingles
    was lookin at latest motor stuff 2day us price saz 5695.95 anyway was tryin 2 see were ya buy dese  motors an lookin an lookin an then readin more into 120r well not bulletproof and as many av found engine self destructin geez dat put me off an i was sure dis would b good motor in further reseach saz 96 - 103 motors made better wont self destruct or less likely to geez its all in da readin an searchin an seein wat others hav found no 120r 4 me but sum will swear is good but seems there is problem even reckognized by s&s 120r donk can b broken in a rather short mileage 4 an aggressive rider on spinnin up a lot twists sumthin an shears oil pump an boing she broke fellas upon readin this an seein piks of damage i no go that way now an i thought it was da real deal HD an if my stg iv 103 dyna destructed was buyin120r but alas wont be now
  • shingles
    shingles
    gday mate yeah i like 120r motor was nex on list if hurt wat i av now but am i jus readin a few isolated motors in 120r  size  were doin damage internally was us pages just an isolated incident an bad press doin rest ,i mean u av 1 dese motors an swear by it ,i shood av gone all da way wen was thinkin about more performance but had 2 try an maintain poket an still av some go ,i hate readin bout mechanical woes by owners who r not impressed ,wonder if our shipments of 120s made 2 different specs than US 120S would av 2 be as we use higher oct fuel  i spose anything can happen regarding an engine A I MEAN more ya read sumtimes can b confuseing 2 us as purchasers i avent read of anyone inoz wif problem an im jus goin by wat guys av had happen will search more ive had 1 of those weeks were everything has in need of fixin except bike but has been soundin strange of late fuk it jus twist throttle as usuall bloody rain all week sendin me insane ,o well if was hot peple b sayin geez wens dis heat gunna stop strange things arent we
    it's only water it's got no soap in it
  • Ando
    Ando
    Shingles, think about this
    the 120R has the same heads as the Stage IV, has a billet cam plate, SE High flow oil pump and a tighter tolerence crank than a stock 96 or 103
    If people don,t have a proper tune and break these motors in correctly they will have problems
    But overall the 120r Donk is a far better bit of kit that the donks ya ride yeh new harley outa the shop with
    The lifters are the only thing that are suspect IMHO
  • Ando
    Ando
    Did you just say he had glazed bores to prove his .012" crank run out
    and for your info the 120r comes out with a crank that is a wee bit better than a stock twincam crank
    this is my crankrunout
    Ando , the 120 motor I saw in Canberra , had a sign on it saying 135hp . Have you had yours on the dyno ? What figures ? Spare parts guy here in Adelaide said there,s around 6 of these motors runnin around here , that they have sold , with no problems .
  • Ando
    Ando
    what the fuck does flogging or not flogging a bike got to do with glazing barrels
    FFS
  • Ando
    Ando
    and I run a stock clutch with a heavey duty spring, but apparently that can.t be done either
    Sorry guys , but going over old ground , If  I was to buy a 120 SE motor from harley , would I have to have the crank welded ? Would I change cams to Tman ? There is also 2 specs , a 12.1 and 10.5 to 1 comp ratio . Think 10.5 to 1 for street . Approx 10k for 120 motor , maybe work the 96 ?
  • ozymax
    ozymax
    you should be able to just run it as delivered although you could upgrade the performance if you wanted to.
    I got a price from HH about a month ago and it was under $7k delivered to Bris
