Baron Tacho
  • Jimmy The Human
    Jimmy The Human
    Hi People
    I ordered one of these for my 2077 FXSTC. anyone fitted one or no anyone or heard of any tricks,,,I must admitt the wireing on these things I'm afraid to say scares me a bit???
    cheers Jimmy.
  • chrise1961
    chrise1961
    Yep and you need a flux capacitor to make them work properly.................... might be a bit optimistic on the 2077 model Jimmy...
  • Jimmy The Human
    Jimmy The Human
    mmmm!! yes I see I was little advanced there on the year model !!! lmoa.....you blokes did have me scratching my head a bit.
    so anymore? :)
    cheers Jimmy
  • Jimmy The Human
    Jimmy The Human
    ok boys
    I have been reading conflicting reports and where the tach wire would be
    a) the pink wire comeing out of pin #3 in the ecm..and it could be just a blank in the harness somewhere??
    b) it could be in the headlight loom at the headlight??
    c) I should be able to find something behind the speedo??
    and yeah it is a 2007 FXSTC,,,no fucking Ion what he said,,,,snicker snicker,,,,or a fucking capitator whatcha ma callit..lol...:)
    cheers Jimmy
  • Jimmy The Human
    Jimmy The Human
    thank you S.M.D.F.
    I am pretty good mechanical minded but I think I will get it done neat and proper buy someone who really knows what there doing.
    cheers Jimmy
  • Jimmy The Human
    Jimmy The Human
    oops                S.D.M.F.  !!!!! cheers.
  • Gnoo
    Gnoo
    tacho pin hole in ecm wont have any wire in it if it's an 07,pink wires came out later,green wire from tacho goes there.
    (will need to buy terminal pin for ecm)
    red an blue run under tank and both join to blue wire in tail light loom (under seat)
    black to earth. (I think baron instructions do it that way) I done mine bout 6 yrs ago,memory could be dusty.
    Hpe this helps fella.
  • Jimmy The Human
    Jimmy The Human
    thanks Gnoo
    cheers  Jimmy
