Online: B0nes
Tank dent removal (paint less )
  • careyman
    careyman
    if its just one of those round dents on the flat of the tank you could try going to a panel beater and asking if he could use a suction cup on it, they may have to spot weld a little pin onto the tank and use a slide hammer to pul it out
  • clarkie
    clarkie
    ther is a guy in warrnambool,trades as ausdent does paintless dent repairs look him up in white pages online and give him a call no harm in asking,
  • ozymax
    ozymax
    try contacting one of the sydney or Bris mobs and see if they know of some on in your area. worth a try
  • trev2305
    trev2305
    i need to find someone in adelaide too, some fuck knuckle in a carpark dinged my front fender, tiny little ding but its all i see, have spoken to a couple of dent guys but they are not keen on touching a harley, maybe the fender metal is too thick to deal with, not sure. if anyone knows a paintless repair guy who can do it i would appreciate the details
  • Wimbo
    Wimbo
    Just buy a new tank mate and get it sprayed.
  • robots
    robots
     Hi,
    don't know about paint less, but try Melbourne motorcycle fairings in spotswood
    they done Insurance work for me, 20cent dent in tank, I would get all tins painted
    thanks
    robots
  • careyman
    careyman
    didnt even know that people offered the service.. last dent I had in a tank i took it to a panel shop (it was a small country town shop admittedly) and he just let me use his tools (suction cups)... not sure if people are like this now days tho
  • taff60
    taff60
    I bought a glue on type puller but it wasnt up to the job. I think the tanks too thick.
    Took it to Ausdent in Geelong, he has done soft tails before but was reluctant to touch my 40 dyna (single central aircraft type filler) as he wasnt sure if he had room to get in and was worried about the thickness of the metal. He also wanted the tank draind and off the bike. Ive seen it done on utube by US repairers, so it can be done. There is a definate need for the same here. If anyone was thinking of a career move.
  • Retroman
    I had a Swiss dude here in Perth do a fair sized ding on my 2006 Dyna a year or 2 ago !
    Goes by the name of the " Ding-King"
    Did not get it out 100% , but a new tank badge made it 99.99% and I was happy to live with that
    Had to take the speedo off the tank and open and lift out the fuel pump etc ( I did all of that !), all fuel gone gone gone !!
    2 other "paintless dent removalists" had tried already with no joy ( and no cost to me !!)
    A new rubber gasket for the tank/pump interface and I was good to go
    Cost from memory $90 cash so I was well happy
    The metal is 1mm thick or so , so most dudes are only used to car panel thickness ( way thinner !!).
    Colour was Glacier White Pearl with red and blue wide coachlines .
    Dent was across all three "colours" and was maybe 12cm long and 1cm "deep" around the original tank badge which had taken all the "grinding" !
    Same guy took a dent out a mate's Ultra front guard ( fender !) 100% no dramas !!
  • paulsails01
    paulsails01
    I went through this same scenario last year, bought second hand tin ware from USA for a project, tank had a small ding from blinker contact.
    I was out of work so money for a panel beater was out of the question, set to the task, viewed a few vids on U-tube and went from there, made my own tooling for the paintless method, small nylon nob on the end of a curved 12 mm rod and with a trady type heat gun worked the dent for a couple of sessions over a couple of days.
    Results were remarkable, patience and attention to heat input slowly worked the dent fold out all the way until the worked tank area looked normal, although my intentions were to paint the tank any way it could have gone back on the sled. I am sure anyone could attempt this who has a bit of time and patience, the U-tube vids were a big help.
  • Fe883
    Fe883
     I have used these guys for the last 15-20 years.
    Company is called "The Dent Maestro" the owner Darren is a great bloke & will come & have a look & let you know then & there if it can be done.
    http://www.dentmaestro.com.au/
    Cheers.
