Shovel Sprocket bolts,, info needed
  • Slick88
    Slick88
    Hi Guys
    Putting a new set of spoked wheels on the old shovel
    I assume that the bolts for sprocket need to be high tensile
    Can any none tell me what grade etc
    Also Will nylock nuts be suitable and should i use locktite (locktite 263)
    Do I need to torque the bolts and what torque setting,, Would 35 FT LBS  be about right
    Slick
  • kickinon
    kickinon
    High tensile grade 3 or more,, wont need to use locktite on nylex nuts,look up the torque settings in your shovel manual.all that imfo is in it....
    grade 8 would be good  allen bolts are grade 12 , make sure there tight as  & check them every service
  • Slick88
    Slick88
    Thanks Guys
