Online: Hilly, Merv
Please help
  • aarongame
    aarongame
     Hey guys I got a softail deuce 2001 carberator bike, my problem I'm havin is when the bike is first started and cold , I let it warm up for 5 min say and then I take off riding and the bike is just got no power for like the first 4 min of riding I can be full throttle and the bike just has no power , and as but after like 4 min of riding its got awesome power and has take off and goes how a Harley should go , please help why is it aluggish at the start? The bike has slip on exhaust , aftermarket cams, macuni carburetor , please help guys I've had the bike for 5 weeks and it's been in the shop for 4 of them weeks and the bike shop trying ta tell me that it's normal, where I think no bike should do that
  • Will67
    Will67
     maybe its telling you to let it warm up properly, or may need to be re-jetted.
  • aarongame
    aarongame
     Mate I do let it warm up, weather I leave it warm up for 2min or 10min it's still does the same thing
  • Wimbo
    Wimbo
    Hmm, I'm the opposite.
    Mine hates the choke and sitting after start up.
    I start mine up with no choke, count to 15 then go.
  • Deadwood
    Deadwood
    My choke won't stay out so I use the throttle lock thingy but I generally have the same issue as your Aaron. I put it down to cams etc and haven't thought about it too much.
  • Cartoon Head
    Cartoon Head
    Several things come to mind.
    Air leak on the inlet side, too heavy engine oil, dirty throttle body, spark plugs fouling, wrong spark plugs (to cold) etc etc.
    The above are by no means a full list but are easy to sort but if your happy that they are okay I would recommend you do a compression test at the very least this would rule out worn top end.
    Without being able to see the condition of the bike it's difficult to diagnosis what is going on but there are some very clever guy's on here who with as much info as you can give will help you out.
  • fat55
    fat55
    nah thats shit , take it to someone that knows what they're doin
  • aarongame
    aarongame
     The bike is under warranty and is in the shop at southport Harley Davidson on the Gold Coast and they say that there is nothing wrong with the bike , but I no and everyone else noes there is , so there trying ta find the problem but don't no what it is, they re jetted it , cleaned carbi, cleaned all fuel tank and lines , and my bike still has the problem and it still back fires out of the carbi every now and then, but they have no idea what it is ...
  • 06 Softail
    06 Softail
    I've been thinking about this for a little while very simplistically, and have wondered if it could have something to do with the ignition system breaking down, and not providing enough spark when required.
    Just my thoughts, I'm no mechanic, but am mechanically minded.  Just getting back to basics where for a motor to be able to run, it needs three important things, Fuel, Air, & Spark.  Check your ignition system, plugs, and possibly your leads too.  You may have a cracked lead, wrong plugs, or faulty ignition system.
     Good luck, and hope you locate the problem soon.
  • Soapbox2627
    Soapbox2627
    I have a 2004 carb nightrain, I also start the bike with the fuel enricher, then push it all the way in and manual keep the revs up, the plugs foul otherwise.
    My enricher knob used to slide in aswell until I found the thread nut that hold it to the frame was lose, tighten it up and it stayed on.
    My bike also gets a miss as I ride at any speed ocationally.
    Your jets clean?
    Does it feel like its starving for fuel or spark, does it smell of petrol
    Is it only from cold or each time you start it
  • aarongame
    aarongame
     The bike only does it from cold , once bike is been riding for 5 min it's perfect , if it was spark or ignition Wouldent it do it the hole time just not when cold ? I can be full throttle after letting it warm and the bike wille just be slow as shit , and then boom the duckin thing rides like a dream
  • scotti
    scotti
    What carbi and or jets does it have ?
  • Will67
    Will67
    maybe the wrong choice of cams have been stuck in and made the bike a pig. a lot of people think the bigger the better but without other mods like head work etc you can kill the engine.
    who put the cams in? is the cam timing correct what cams are they what other work has the bike had done??? all this info will help people help you.
  • aarongame
    aarongame
     The problem is only when it's cold not the hole time , I brought the bike as is all I no is that it has a macuni carberator and after market cams, the cam were some from the previous owner at one of his mates houses not done at a shop , sorry I don't have a lot more info on the bike, but yer once again if the bike only does it when it's cold why when it gets warmed up does it go good ?
  • Soapbox2627
    Soapbox2627
    it has to be a lose something, when it heats and expands, close's up.
    I hear a bit around this flapper thing in the exhaust, could that be closing and sticking shut when it goes cold, when the pipes expand with heat, it releases?
    I really don't have a clue, but am only thinking out loud, but it may give some of the mechanical people in here another train of thought
  • Wimbo
    Wimbo
    Maybe your just flooding it and it takes 5 mins or so to clear.
  • aarongame
    aarongame
     I start the bike with no choke and it starts and idles perfect , it's just when I go ta take off it is just slow and has no go about it , when it's tuning slow it does not chugga or piss and fart ot sound normal but just does not have any get up and go, and then all of a sudden after about 4min it's awesome to ride besides it back fires out of the carbi every now and then
  • aarongame
    aarongame
  • ozymax
    ozymax
    been a long time since I had anything to do with carbies but a simple place to start is check the float level.
    no need to pull the bowl if it has a bottom out over flow line. Change the line to clear hose and point it up to above the float level. it will find it's own level. inside = outside so it will be easy to see if it is to high and causing minor flooding.
  • aarongame
    aarongame
     Would it fix the problem if I changed the hole carbi to a new one? Do ya think that that's the problem
