Tank cross-over quick release valve
  • Marvin
    Marvin
    Does anyone know where in Perth I could find a quick release valve for the petrol tank crossover line?  And any rec. on experience with a good one - no leaks!
    Cheers,
    Marvin
  • imoo6170
    imoo6170
    Old post but some of the options may be still available
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=15&postid=222272&view=topic
  • Ando
    Ando
    Marvin I just got some fuel line and fitted T piece in the between and a run off a line cable tired to down tube
    I just put the run of tube into a fuel tin and drain the tank before I disconnect fuel lines to remove tank, not a drop of fuel ends up on the floor
  • Marvin
    Marvin
     Thanks Ando.  Was looking at that as an option.  If I can't get a good quick release I'll go for that.
  • Marvin
    Marvin
     Thanks gents, saw those cpc ones myself - was hoping to be able to buy something in Oz!  Sounds like they do the job so will have a look.  Assume no issue with the fitting, saw it is 1/4" and the Softail hose is 5/16" ID?
    They do a 5/16" version as well.
  • Gonads
    Gonads
    My softy was 5/16th's. Also got them to send 2 sets of spare seals just incase had a problem down the track. They cost sweet FA and gives a bit of peace of mind.
    Tried to get them here in Perth through pirtek and some other places to no avail. Some places hadn't even seen them before! Came quick enough from the US anyway.
  • Marvin
    Marvin
    thanks gents, going to stop hunting locally and order some now.
  • blueystar
    blueystar
    Should do a group buy postage is high doing by your self
  • jacko88
    jacko88
    similar available on OZ EBay for 29.00 + free postage
