softail dipstick
  • damo08
    damo08
    hi all i own a 2008 softail standard 1584cc... ive been told different stories and cant find anything regarding it in my manual.... do i push my dipstick in all the way or do i leave it resting  on the rubber seal when checking my oil???? thanks in advance...
  • damo08
    damo08
    thanks.... ive been doing it on the side stand as per the manual but ive had conflicting stories about the dipstick being pushed in or left out on thr rubber.... i thought id ask on here coz i knew someone on here would know for sure
  • Cartoon Head
    Cartoon Head
    It just goes to show you how something so simple can cause confusion, just make sure you check it when the oil is warm otherwise you will get an incorrect reading.
    Asking questions is one way we all learn damo08, I heard a story off a mechanic years back about someone who had filled their engine with oil all the way up to the oil filler! I have my doubts if it's true though, probably just another urban myth.
  • Ando
    Ando
    I seen a sparky at work filling a hilux through the dipstick
  • Crazy Erny
    Crazy Erny
    Yep, all the above correct, except you should be checking your engine oil at running tempetures. The same applies to your gearbox, but with the gearbox plug you don't screw it all the way back in to check your level, you simple let it sit on the top thread in the gearbox then measure it!~ Do check both a couple of times each!
  • Crazy Erny
    Crazy Erny
    Cheers Roster, what is important is to never overfill, & as far as draining is concerned it's not possable as the oil has got to get passed the oil pump to drain which is not possable with the engine turned off. I could be wrong but I doubt it!
    Harley and Porsche, it's a lovely mix.....
  • KiwiRob
    KiwiRob
    In the soft tails, oil will drain past the oil pump & into engine over time. If bike has sat for some time, oil level will be low, so it is best to run engine for a minute or two then check level after shut down. The problem is worse with some aftermarket pumps that don,t have the wavey spring between the pump gears like the HD pumps have.- Rob
