Remove Stage 1 ECU tune? 2005 FLHTCU
  • Andysdad
    Andysdad
    Hi all,
    I have a 2005 FLHTCU with Stage 1 map flashed into the standard ECU plus a PC III with an additional map.
    I would like to revert the standard ECU to factory - does anyone know if Dealers can do this (if yes, how much $?) or do I need to find another ECU (about $200 from USA on eBay).
    If it is another ECU are US market ECU maps the same as Export (e.g. is Australia map different from Europe/US? Or is 1HD same as 5HD?)
    Thanks in advance.
    A
  • Cartoon Head
    Cartoon Head
    Andysdad, Are you sure the ECM has been flashed? as I don't see why with a PC111 fitted it would have needed to be.
    A PC111 is a piggyback system which has the map loaded into it so just remove it and the ECM will be as it was.
  • JD
    JD
    why do you need to bring it back to standard if it has been flashed
  • Retroman
    PM sent
