vance hines
  • sedgez900
    sedgez900
    hi out there in there need some help r vance and hines short shots a good system for your bike cheers
    Depends on what you mean by good. They are loud, some people absolutly love them and others don't.
    Btw, since you're looking at buying these from a forum member its poor form (and not too smart) imo to ask other members of the same forum their opinion. There's plenty of places to do your research.
  • sedgez900
    sedgez900
    u misunderstand mate r they a good system for performance
  • clubbie
    clubbie
    Are you buying just the pipes or do you have a intake and tuner in mind/budget. They will piss you off in the first 25kms without an appropriate tune and not a downloaded map. They pop like a mofo.
    As for peformance you will enjoy the looks and noise.
    Do a search on this forum, quite a few posts.
