Pegs/forward controls - 50% rubber??
  • Lucas
    Lucas
     Howdy,
    Ive ward that when modifying or building a bike, rego requirements are that grips/pegs and forward controls have to have 50% rubber: does anyone know if that's definitely the case??
    Some Jap sport bikes have aluminium pegs , and some dirt bikes have steel pegs . My 2c worth.
  • Maxiboy
    Maxiboy
    If the rubber is there it must be in servicable condition. If you put alloy ones on that's fine too. Go figure!
  • Will67
    Will67
  • Lucas
    Lucas
  • Lucas
    Lucas
    Ah ok, thanks Will. I'm building a bike from scratch, and I want knurled/milled stainless and brass forward controls and grips. But I'd heard an engineer won't approve it unless they're 50% rubber. Of course I'll do a little more research, but just thought I'd ask members here first..
    Cheers,
  • Ross
    Ross
    Mate if your building a bike, get very familiar with the ADRs or expect the engineer to keep saying no.
    And don't forget that each state has other additional rules and discrepancies.
    http://www.infrastructure.gov.au/roads/motor/design/index.aspx
  • Lucas
    Lucas
    Yep will do, thanks for all the replys..
    Yes must be a minimum of 50 per cent of rubber on both
  • Lucas
    Lucas
    No worries guys, thanks for that...
