Online: tussuck
Dyna rear wheel/tyre change with no help
    Though you prolly know, if you're leaving your bike on the lift for any amount of time you might want to engage the saftey lock bar thingy near the pedal, because hydralic jacks have a habit of going down when left too long.
  • cm364352
    cm364352
    I remove the bottom shock mount bolts and let the swinarm drop.That way the wheel stays on the ground.Never had a problem doing it that way.
    I also like to chock the front wheeel when I am doing this,just to be sure bike can't overballance when the rear wheel is removed.
    WAZ...
  • AJ56
    AJ56
    Like anything working on your own you need to be a bit inventive. I have taken the rear wheel off my heritage about 5 times now on my own. As Hmmmm 2 said. the rear wheel just touching the ground on assembly is a help, and take your time. I sit at the rear of the bike straddling the rear wheel. And then just struggle the fuck out of it.. Oh and grease the shit out of the axle... Also put the axle in from the left (opposite to the exhaust).
  • pat
    pat
    If you put the nut on the right you won't have to take exhaust off next time
    Can fuck up some axel chrome trim sets, some r ok
    I had drama going with a newer wheel set, abs spacer about 5mm thinner
    Because of fancy fatter abs sensor bearings
    1/4 12 point socket will get the pads out of the way, hard to find in most socket sets
    i lift the bike up high, get wheel under the gard, if its a belt it's harder, chain is easier. with belt remove the belt gards. put wheel in place. i have a thick block of wood to lift wheel up sit it on.
    then make sure brake pads are open & eather side, loop belt or chain over drive sproket get the disc into caliper get spacer in place have wheel up on block then while holding spacer on brake side in place, lower the bike till axl hole lines up put a bar or an old axle in one side to hold everything in line then push the axle through on other side. i always coat with anti sieze.
    thought i'd mention , mine is easy as i have an out rigger bearing support on drive side, this bolts to outside of drive sproket takes the place of the stock loose spacer, & it has a sealed ball bearing press fitted inside. best thing ive done to upgrade a HD, been doing this since early eighty's never bent an axle or had a bearing fail yet.
    think about it, you got a wide spacer then the swingarm , when the drive belt pulls on sproket it can put a lot of stress on axle. with this set up you have a machined block of alloy the sproket bolt patern drilled in it's machined off then sealled ball bearing press fitted in its bolted to outside of sproket so in effect you move your wheel bearing up beside the swingarm on drive side, you get extra support & a  extra bearing supporting all the weight. & as a bonus makes solo wheel change easier.
     I agree Hilly, but guess it would add costs. First time I did that was with a striker shovel it bent axles all the time. Tried to get stronger axles made up but they bent too , then a bike drag racer from QLD built a new drag bike with a huge slick. I looked at his rear axle and it was not that thick. Asked if he bent axles & he said no. Told him about my prob & he said get the wheel bearings as close to frame as possible. I thought about it, told a m8 & he said give him rear wheel axle & swing arm .so took them off & he made that. No more bent axles. But new HD have a thicker axle but that out rigger bearing would help in more ways than one
  • robots
    robots
    Hi,
    I just put my wheel back in tonite, yeah keep wheel just touching floor, with the dyna I put big left side spacer in first and then put socket handle thru swingarm, spacer and into hub to hold in place
    Then did right side spacer setup and put axle in
    One thing I notice is belt has become quite tight even though I didn't touch the adjusters?
    The other thing Is I took brake caliper off with pads in it, are the pads something I can get back in easy enough?
    Thanks
    Robots
  • robots
    robots
    Hi,
    Thanks, I made one of those coat hanger alignment tools so will double check with that
    Thanks
    Robots
