4" curved risers
  • mickjen
    mickjen
     Hi i have a 2013 super glide and have just brought a set of 4" curved risers, my question is do you just remove the stock risers and leave the rubber backed spacer's on the tree and do you use the stock washers with the new bolts, the reason i ask is because the bolt's that come with the new risers are way shorter than the stock ones, also is it wise just to put a bit of blue lock tight on the bolts.
    Mick
  • ozymax
    ozymax
    not sure about the bolt length but if the came with the risers I would use them unless it is obvious they are to short.
    Yes leave the rubber bushes and cap washers.
    I never use locktite on mine, mainly because I am always undoing the fuggin things
  • mickjen
    mickjen
     Thank's for the reply ozymax, got it all done with no problems, i can sit well back in the seat now with a bend in my arm's.
    Mick
  • ozymax
    ozymax
    one thing to check after tightening it all up is if the bars are square. I have noticed a few times when I sit on the bike they are pointing a bit off. Just back the bolts off a little and go again
