Online: speedzter
02 sensor 6in ext cable
  • 666
    666
     hey anyone  know where i can find an ext cable for my rear 02 sensor ????
  • Cartoon Head
    Cartoon Head
    You need TXL 18 gauge wire or good quality automotive wire.
    Just found this while reading through the EFI section (Page 10) that was posted by Ozroder (R.I.P) which will hopefully help you.
    http://namzcustomcycleproducts.com/products/O2_sensor_extension_kits.html
  • 666
    666
     thx for the link thats a different set up to mine
