Online: speedzter
fatbob shocks
  • chriso
    chriso
    ok the progressives for the back i am after can still have the chrome cover over them that comes standard. I know they are availible but dont know what they are or where to get em. hoping to get some help. Does anybody know about em?
  • jocky
    jocky
     yeah chriso got mine from m&m,not avalible in aussie.
  • chriso
    chriso
    Thats them jocky, finally,how long ago? Are m&m still exporting Harley parts, what are they called, how much and are they any good? Thanks mate
    EDIT: just having a closer look and not sure if they are the same, they look squarer at the top.
    give me the rundown anyhow and ill chase it up. Cheers
  • ozymax
    ozymax
    http://www.ebay.com/itm/Progressive-Suspension-Shock-Absorber-412-4042C-Harley-FXDF-Fat-Bob-08-12-/271100264661?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item3f1ed5c0d5
  • chriso
    chriso
    thanks Max you da man
  • jocky
    jocky
     yeah no worries chriso,got them 12mths ago,couldnt get them here with full cover as one pair of shocks,could get the shocks
    but the cover had to be imported as a seperate item. to hard & to expensive. pushing $500.
    looked at mm  got thm deliverd for around $360 $380 have to look for the receipt later.
    have got mine set pretty low as that is what i wanted, so little on the firm side for my 75 kg
    having said that,i love the look of them, and they look good from the rear aswell,
    nice n chunky....solid....tufff,you know what imean.......jocky
    Check out the Progressive website and pick out what you want , then order them through a supplier with the right code , I used JC Motors .
  • chriso
    chriso
    champions you blokes,cheers
  • chriso
    chriso
    correct me if im wrong but it seems the ones with covers only come in the 412s
  • ozymax
    ozymax
    you are correct and only in stock length 12" black or chrome
  • chriso
    chriso
    fuck the covers, pulled the trigger on a set of the 444 series, new release. want somethin good, not the bottom end of the marke. $580 delivered from aussies link above ,(cheers mate) as opposed to over a grand quoted locally, and they want us to keep our money local... HOW???
