Online: B0nes, speedzter
Electrical Issue!!
  • Rumpig_63
    Rumpig_63
    Can anyone tell me what the issue could be:
    I stopped my bike at a mates place and when I came back out it was as if the battery was dead, had to jump start it and then noticed I had no electrics ie: lights, indicators, horn or speedo!
    The bike is a 99 Fat Boy evo motor.
    Any Ideas or can you point me in some direction, thinking stator or voltage reg?
    Sounds like a stator or regulator issue. You end up having enough grunt in the battery to start and run the bike for a long while, but once you stop, there's not enought to restart the beast.
    Run through the tests to see if the battery is being charged..that will tell you.
  • Rumpig_63
    Rumpig_63
    Thanks guys I was thinking it might be along those lines!
