New speedo/tacho
  • Sparra
    Sparra
    Hey fella's...Thinking of swapping out my speedo on my 2010 Wideglide...Just wondering from anyone who has changed one whether you need to wire in the tacho or does it just start to work when the new combo is plugged in...
    Cheers...Sparra
  • FatRob
    FatRob
    On my FatBob it was just a case of connecting a multi pin socket thing into the new unit and away it went.  No extra wiring needed.
    I'd imagine the Wide Glide would be exactly the same.
    FatRob
  • Will67
    Will67
  • Sparra
    Sparra
    Thanks for the reply's and link...I see it remembers your milage...My bike is in MPH so hopefully it will change that to KPH when the new speedo goes in...
    Cheers...Sparra
