Online: B0nes, speedzter
auto compression release on 2012 and later models
  • dreamer
    dreamer
    g'day guys just want to know  how does the auto compression release works on late model bikes and where is it fitted. thanks in advance
    • New Parts
    • Gift Card
    • Gift Ideas
    • Engines
    <form>> name="harley_add_to_cart" method="post" action="http://www.harley-davidson.com/gma/gma_product.jsp?WebLogicSession=Q1oMfgkL2yMYlCeEWuPbf22AK8FmMfXJUJtBC4MHBnKcuK3HQF5S!-1837328189!hiwpbmsp04.ihd.hd!7005!8005" style="margin: 0px; padding: 0px;">   </form> <form>> name="harley_add_to_wish_list" method="post" action="http://www.harley-davidson.com/gma/gma_product.jsp?WebLogicSession=Q1oMfgkL2yMYlCeEWuPbf22AK8FmMfXJUJtBC4MHBnKcuK3HQF5S!-1837328189!hiwpbmsp04.ihd.hd!7005!8005" style="margin: 0px; padding: 0px;">   </form>
      Shopping Cart
    0 Items $0.00
    Advanced Search
    Automatic Compression Release
    Automatic Compression Release (ACR) valves reduce the strain of starting your high performance motor by reducing cylinder compression - automatically! The engine is easier to turn over resulting in less wear on your starter and battery. After start, the ACR valves close to restore full compression. ACR give you peace of mind and protects your investment. ACR can be installed on stock or Screamin' Eagle® Performance cylinder heads for all '07-later Twin Cam equipped models. Install requires machining to be performed by a competent machinisht using the Screamin' Eagle® Automatic Compression Release Fixture Kit P/N 94648-08 (sold separately). Installation requires separate purchase of model specific ACR Wiring Harness.
    28861-07A
    Go Light
    Fits '07-later Twin Cam equipped models. Can be used with Original Equipment or Screamin' Eagle® Cylinder Heads. (each)
    MSRP US $39.95
  • ozymax
    ozymax
    or on a very late model it could be by way of the easy start cams
  • terroristone
    terroristone
    They are located in centre of heads, hard to see but they are there, you will need to remove the rocker covers.
    T1
