Online: Hilly, Wanderer57
Throttle % at cruise
  • Surly
    Surly
    What percentage(s) of throttle is normally used at cruising at 100 in either 5th or 6th?
    I can tell from the hours of use what rpm points I am hitting the most just not sure which table this is likely to be on.
    Surly
    ps 2007 Softail with SE quiet slip ons and big sucker with TMAX
