Online: B0nes, speedzter
How Do I remove my starter
  • chopa
    chopa
     Now do I remove my starter on mt 96 Wide Glide. Is it just 2 bolts or is there a bolt inside the primary?
    Chopa
  • taff60
    taff60
    Primary cover off. There should be a bolt holding the jackshaft to the starter . Then the two bolts!
  • rider
    rider
    Chopa, do ya self a favor, get yaself a manual from api.viglink.com/api/click
    the ten bucks will be the best investment ya make.
  • chopa
    chopa
    Thanks guys for the info. Yeah Rider I have a manual but doesn't really explain it well. It did mention the jack shaft bolt but I just thought it a bit strange that there was 1 bolt behind the primary. Ah well off with the primary it is.
    Thanks again guys
    Chopa
    Yep...great manuals. I also bought the factory paper one on eBay for $30. Took a few months of waiting but one tuned up in the end.
