Online: B0nes
Heavy Duty Ramp
  • Pastrypete
    Pastrypete
    Need to find a heavy duty ramp as my ride is getting relocated into a shed and I need a ramp more than 450kg capacity . I can only find ramps with maximum 340 kilos capacity ...any help appreciated...regards Pete
  • oneball
    oneball
    Hi all...Ppete,Is it possible to pack the middle of the ramp ? If so you dont need the ramp to be as strong as the weight of the bike.
  • Pastrypete
    Pastrypete
    The actual height that I need the ramp for is 22cm ...so at the moment I'm looking at all options ...ie chequer plate , wooden ramp, etc . I may be able to just put a chock of wood under the middle of a cheaper bike ramp ....need to go look at em
    I use a ramp I got from repco (black, steel thing) which is 363kg rated so no good. What's your bike btw? A streetbob is 300kgs, a tourer is around 400?  Ultra 410?
  • ozymax
    ozymax
    the full load of the bike may not be on the ramp so you may not need a real heavy one.
  • Frank7214
    Frank7214
    Piece of wood does the trick for me.
  • Pastrypete
    Pastrypete
    Superglide custom ...Bonkerz ...was also taking into account rider weight plus some extra kilos. Will probably go with a standard type one with a chock of wood under the middle for piece of mind
  • fat55
    fat55
    got mine from Whipp's on the central coast , 500kg rating
  • Pastrypete
    Pastrypete
    Saw the whipps ramps online today fat55...they looked pretty pricey but well made
  • scotti
    scotti
    Yeah cheap way out is to bolt a pair of the black repco (CRA ?) suckers together side by side !
  • Pastrypete
    Pastrypete
    Whys that Seedzter ...seemed like the easiest option to me?...the incline is only 22cm meaning I can still touch the ground
    I was actually thinking you were loading into a ute !!  I've seen to many Fark up loading a bike like that.
    I usually just walk the bike up using the motor/clutch.
    But into a shed maybe not such  big deal, but it does mean you can use a lighter ramp !
  • Ross
    Ross
    Go to the local engineering firm and get them to weld some angle on the back of he cheap ramp, or even fab you one from scratch. It's not a hard job and if your not carting it around all he time, they can make it strong as you like.
