Online: bikenut57, John.R
Speed sensor
  • alf 67
    alf 67
    I have a 98 dyna wide glide with a speedo problem just wondering is there anyway you can test speed sensor?
  • jacko88
    jacko88
    take it out and clean any metal that may be stuck on the magnet first before checking wiring etc as thats the most common cause apart from a buggered sensor
  • AJ56
    AJ56
    About the only thing you can do is replace the sensor. They are a sealed unit.
  • alf 67
    alf 67
    Thanks for that AJ
