Online: Hilly, Wanderer57
Mod Claims to Stop Slides
  • Fantm2
    Fantm2
    Would this idea work on rear brakes as well by making the application a bit more progressive (taking the initial 'bite'). Often riders pull in the clutch jump on the rear brake pedal and lock up in a panic stop.
  • whiteyluvsrum
    whiteyluvsrum
    flan & skull- ive just noticed that your avatars are almost identical, not including the bike and backgrounds.
  • gonzo
    gonzo
    So...
    Does this mean that all those who have replaced their standard brake lines with steel-braided ones in order to (amongst other things) reduce the flex, now have bikes that are more susceptible to wheel lock-up? I can see the logic in the device - it absorbs pressure spikes to avoid lock-up - but it goes against the commonly-held belief that reducing flex is a good thing.
    Gonzo
