• bully
    bully
    Can someone please tell me what type of petrol to use in my 2011 fatboy lo I have had different views of what to use thanks
    BP ULTIMATE 98 Unleaded..
  • HogBag
    HogBag
    Depends how much you squeeze your chosen cam with what octane rating to use.
    look in your harley manual or ring the Dealer
  • jocky
    jocky
    BP ULTIMATE...98
  • Ross
    Ross
    I've heard unleaded works better than diesel and gas...
  • glucky7
    glucky7
    just buy the best you can aford mate
  • BigV
    BigV
     If its tuned (pipes, filter, ecu), then 98 (otherwise it'll run too lean and hot). If stock, then 91 is fine...
  • bully
    bully
    thanks for your help i have enough sense that they dont use diesel or gas as ive ridden harleys for 30 yrs thanks anyway
  • KiwiRob
    KiwiRob
    95 or better, although 91 will work if need be. - Rob
    BP Ultimate 98, would be better  for your motor as thats EFI they might not be high comp but they are air cooled EFI run . that 98 keeps the injectors clean
  • taff60
    taff60
    95 for me, 98 does ok but no real differencethat i can feel. 91 seems to lose a bit of power.
    Mine runs like crap on shell ultima..........avoid it like the plague.
    Used 95 ron ethanol blend by mistake the other day (ultra servos), didnt go too bad but was all highway use. Wouldnt make a habit of it though!
  • BigV
    BigV
      If its tuned, just run 98. I always fill-up with 98.
  • the_mongrel
    the_mongrel
    Ok... Here are the facts... make of them what you will.
    BP Ultimate is a highly refined petrol with an exceptionally high octane. It has been designed to be used in the following vehicles:
    • modern high performance cars and bikes designed to use unleaded fuels of 98 octane.
    • It can also be used in cars and bikes designed for Premium Unleaded Petrol (96 octane) but performance benefits may not be so apparent unless the vehicle is fitted with a knock sensor that can adjust the engine to take advantage of the higher octane.
    • Pre 1986 cars and bikes and Classic cars and bikes - with an additive to protect against valve seat recession it can also be used in pre 1986 cars that require higher octane fuel. In terms of octane it is equivalent to the British 4 star grade and so is suitable for many classic British sports cars of the 1960s and 1970s
    Performance and Economy
    Many imported and higher performance cars, particularly those with turbo chargers, are designed to get best performance from a 98 octane fuel. These vehicles can use lower octane fuels however the necessary ignition timing adjustments required or the action of the knock sensor can result in decreased performance, increased fuel consumption and increased exhaust emissions.
    BP Ultimate allows engine management systems to optimise the ignition timing to give full ignition advance for maximum power. Vehicles will then achieve the performance, economy and emissions that the cars were originally designed for, provided they continue to use the 98 octane fuel.
    Cleanliness
    BP Ultimate contains a deposit control additive to keep inlet valves, fuel injectors and other fuel system components clean. The additive is one that is approved by the USA Environment Protection Authority for controlling deposit build up in engines and so maintaining peak engine performance and assisting to minimise unacceptable exhaust emissions.
    Pre 1986 cars and bikes will obtain an appreciable benefit from using BP Ultimate provided they also use a suitable additive to protect valve seats from wear
  • Blackbob
    Blackbob
    when ya live in the sticks ya put in whatever ya can get i like the 95oct but got home with 2 stroke in the Sporty with no other choice back in the day when they ran on carbs you young Fellas would'nt know what they are carbs that is
    ^^^^^^^^^^^^hey Hilly...........why do the yanks always have diffrent sizes, octane ratings, shoe sizes, Dress sizes for FLSTC, T-shirt sizes than us? Just wondering.....The turkey is hitting the spot!!!
    Hey I did not enter 3 times WTF? BTW BP95 for me mostly.
