Torx head screw adapter sizes.
  • 06 Softail
    06 Softail
     Hi guys, I've just bought a 3" extension kit for my forward controls, I was just wondering if anyone has ever fitted these before? I need to know the size of the torx adapter to remove the screws holding the mounting plates to the frame because the ones I have are all to small. Cheers.
    Take the bike to whatever shop you're buying from and ask them to get you the right one. Check the prices first (as some are shocking) but buy a good brand - in my kit I bent two bits, and shredded a bolt just as a third snapped. I bought a set of Kincrome ($28 for 10ish) and they worked well for me. The fucked head needed old school persuasion to remove...I live and learn. Be aware they are usually glued in with blue loctite.
    I tossed all the bolts and replaced them with allen key headed bolts.
  • 06 Softail
    06 Softail
    Cheers Bonkerz.
  • ozymax
    ozymax
    I got a set of torx from the stealers, bent type like alen keys, think they were about $12 from memory, used most of them and never had one slip yet.
  • Nomada
    Nomada
    There's a tool shop at paddys market on main north road.. You might find a set there at a decent price.
    I also saw a set at Bunning a few weeks ago.
    I've got a small set but only go to T40 if it helps.
    If they're really tight use some heat
  • oneball
    oneball
    Hi all...I bought my Kingchrome torx set from bunnings,Was cheaper than anywhere else.Think i only paid about $25.00
  • trev2305
    trev2305
    bought a set from RipEveryPoorCuntOff (repco) they seem ok, use em with a 1/4 inch socket
